Either one of your ignition coils has anternal short, or is shorting to ground. If you can disconnect the pulse generators wires from both of them, and remove the spark plug wires from the plugs, and disconnect the battery. Then using a multimeter, set on ohms scale, insert the probes into the spark plug caps 1 in no. 2 wire, the other in no.4 . then do the same to wires 1 and 3. your readings should be the same. Thats to find if theres an internal short. to find out if you have a short to ground, stick one probe into each spark plug wire, and stick the other on the frame. A low reading means you have a short, a high reading means youre ok. My guess is one of those coils is toast.
