101 - 120 of 313 Posts
Discussion Starter #101
redbaron wrote:
Just remember on using Ford parts, the Fiesta was recalled.....:cheeky1:....
:shock:OH ECK on the ford recalls got a ford axle,ford hubs-brakes etc.
sounds like i may be on:hovering::D
Idont care who you are thats funny :D
Wait a minute that same stuff Im colecting for my build:shock:
That's why you can find the Fords in the junk yards.
"FOUND ON ROAD DEAD"
Hey wait a minute! I drive Fords!!:shock:
Discussion Starter #104
Connected brake pipe today from axle to rear master cylinder,got all air out and got a good brake pressure,then developed a small leak from stainless hose that bolts onto axle so will have to replace stainless hose:X
Tell em send you another its under warrenty
Discussion Starter #106
Jim at Tri-wing rang melast night,i did'nt know butthe end of stainless brake line splits and theres a brass olive inside that must'nt be seating properly so will have a look today.
Had the driveshaft-coupling machined & welded other day.on trying on trike in gear with engine running there seemed at bit of wobble and movement.As having it welded can draw it to one side
The pinions on axle end & engine end allow a little movement but to much will wear them out in a short life span.
Having it checked on lathe at machine shop monday.
Found these exhaust 2" steel bends on ebay will make life simpler fabricating.
yes they will split if the flare is run to deep by flare tool or tightend to tight but norm shouldnt split
Discussion Starter #108
When i had driveshaft-coupling cut-welded last week the weld pulled the driveshaft out of line.Had it straightened,machined today will refit and test tomorrow.
Connected brakepipe,soon as full pressure was reached the brass olive in both couplings failed.Took pipe to local hydraulic company today,they said olives were'nt seated properly,refitted them and replaced with new pipe £5.
Will fit and bleed brakes tomorrow.
Good catch better to see it now than on the road.
Discussion Starter #110
Aint no fun pumping pedal removing all air then soon as full pressure reached,leak appears:X.
Still better now than fully loaded on a steep hill or bend:shock:
Discussion Starter #111
Brakes are now fully bled and operational,Driveshaft nowrunning true.
Gave the underside of body 2nd coat of underseal,edgeing trim arrived today for around seat will fit tomorrow.
:waving:Looking good!:p
Good idea on putting the undercoat, Fiberglass is NOT water proof & will damage it over time.
Discussion Starter #113
American racing anson sprint wheels have arrived in uk,so should have them shortly
Secured brake pipe today,hoping to make a start on exhaust at weekend.
Discussion Starter #114
American racing; Anson sprint alloy wheelshave arrived 15x7; 4x108
Putting Federal 215-60x 15 tyres on rims.
Discussion Starter #116
Stainless steel bumper formed and shaped to body on rolling machine.
Bit of protection from rear enders.
Stainless will get a final polishing now its been shaped.
very nice. using that extra trunk space already i see.
Discussion Starter #118
Certainly comes in handy the extra space;)
Discussion Starter #119
Looks like be having a break ,white stuffs returned.
Discussion Starter #120
Polished stainless bumper starting with black 1st stage stainless polishingcompound with hard mop,then white polishing compound was used with slightly softer mop.Finishing with soft mop and polishing paste.
