141 - 160 of 313 Posts
Discussion Starter #141
Cut heatmat cloth and glued it to outside floor body of boot.
Fitted boot body onto chassis,sealed with sealant for leaks and bolted
Fitted toolkit & auxillary air line into boot.Just needs carpetting when bodies finally fitted.
How bout putting the tool kit standing up in the corner to free up that floor space.
Heat shield is good idea.
It's getting there:hoppingmad:
Discussion Starter #143
Good idea skip but drilled boot for bolts so will have to leave it in the corner.
Fitted handbrake bracket after painting,working fine.Took trike out for another small ride,increased air in rear shocks and seemed to handle better.
More space in boot now its been increased in width.
Cut cardboard templets for front mudflaps will shapealuminium and polish.
Getting closer to just rideing , looks good
Discussion Starter #145
Repositioned toolkit to standup in corner,freeing up floor space,good call Skip;)
& Carpetted boot.
i wish i was this far on with mine , your nearly done , oh were did you get you 416 progressive shocks from , how was the cheepest ?:?
Discussion Starter #147
Got the 416 progressive shocks from; One stop moto. US $312, $387shipped.
The air connecter kit to link to on boardcompressor is included in kit.
How is the body put on? :sadguy:
Is it well supported if you hit a bump in the road?:sadguy:
Is the trunk space will sealed?:sadguy:
:cheesygrin: Looking GOOD
Discussion Starter #149
Body is bolted to top frame,will also seal to top chassis.
Boot has rubber seal around edge where it meets body,it is a good fit will seal with silicone sealant also.Seat is very good fit also,going to put a rubber seal where seat meets body;)
Discussion Starter #150
Cut & shapedaluminium to fit body for front mudgaurd-mudflap extentions.
Aluminium will be polished to mirror finish with polishing compound and mops.
Will be fibreglassing lower body spoiler putting lip around where i had cut for chrome exhaust pipes.
Discussion Starter #152
AMSOILER wrote:
Very Nice Job Big Al....wish I had the talent to do that myself...
Im no fabrication expert and only have normal DIY tools.
When your on a tight budget and cannot afford to pay someone else to buildthe trike project;Its supprising what you can do.Have been fortunate to have a buddy helping now and then with a engineering background.;)
I have a 95 1500 Aspencade and when I am able to get a Newer Goldwing 1800, I plan on Triking my 1500...so I am paying attention to all of these Trike Projects for sure...
Discussion Starter #154
With you still being on the road on the 1800,Lots of time to play around building one then:cheesygrin:
Good job,big al59
Discussion Starter #156
Cut carboard to mould around cutouts for exhaust,covered in aluminium tape,coated with release wax.Cut glass mat and fibreglassed to shape.This will add strength to lower body spoiler,cut for chrome exhaust pipes.
Fibreglass will be sanded smooth then gelcoat applied to smooth finish ready for paint.While i was fibreglassin gave body 2 extra layers i'd cut for handbrake lever.
Cut wing piping seal rubber glued to body with contact adhesive to seal around seat.
Nice job, see fiberglassing isn't that hard & you can do so much with it.
Don't need gel coat, just body work & prime.
Discussion Starter #158
Can Handle small jobs,but would,nt fancy a full body.Will get a bit of body filler to fill round fibreglassin exhaust cutouts;)
Discussion Starter #159
Chromed VW Beetle rear lights ready for fitting to body:cheesygrin:
they look good i may use a set on my 1500 but i'll probably paint them.
