My Antenae/passenger armrest is loose and I located two screws in the trunk that hold the left small cargo compartment but the compartment will not come loose at the bottom so I can get to the area to tighten this bracket. Is there some kind of clip holding the bottom? I'm afraid I will break it if I pull on it. Also is there a manual that describes how to remove all of the panels safely?
Thanks for any help.
Trike2011 look again in your trunk there are 4 screws that hold the rear speaker/arm rest on. You will need to take all 4 of them out the two at the bottom may be hidden buy your trunk carpet. Hal
There are a couple of big bolts under the chrome garnish holding the antennas on. You;ll have to take the side pockets off to get at them. About the side pocket being stuck... there should be three screws. there is also a snap tab at the bottom... be careful or you'll break it...
