when shiftin up or down on & off the ACCEL grip:lash:
i have a clunk sound reminds of a 58 ford auto trans
clunk with bad spline or u joint on drive line
Is the bike new to you? Have you logged enough miles that you are failiar with the norm? The reason I ask is that some clunk is normal when shifting gears. If it's new I would look at U-joints first.
If it has more than 100,000 miles just go to a trike shop and pick up a new final drive. I got the whole thing, swingarm, brake caliper with pads, rotor and all for $50, brand new.
There can be a bit of noise from the slack in the drive system depending on one's shifting technique. Fairly common on shaft drive bikes.
:smiler:thanks for your thoughts
bike has 65.000 miles on it i have put 20.000 on it every thing works great just hear
this clunk might be normal wear
thanks papa
