I have a 2002 GL1800 with 77k miles and have a small fork seal leak and hard suspension which is probably the anti dive. I'm not sure the springs have been replaced so would like to do the seals, bushings, and springs. Does anyone have a recommendation on progressive vs race tech vs traxxion? The traxxion ak20 is too expensive. I would just be looking for the springs. I am only 5'6" so one concern is the stiffer spring raising the bike higher. The right fork has a damper. Does the damper need replacing at some point and how can you tell? I have also read people deactivate the anti dive after putting on heavier springs (1.2mm)
