Let me explain, my father in law bought the bike because of the low milage(2,400). I warned him about the fact of the bike had to set up a long time. Anyway I got it home and of course it would not start. There are no error codes,has good fire but doesn't seem to be getting fuel. It will rotate over great but will not hit a lick. I went ahead and installed new plugs, cleaned fuel tank and noticed alot of rust on fuel pump. I plugged the pump up out of the tank and checked for voltage while depressing starter switch. It has battery voltage at the pump. I removed the seat from my 08 GL1800 and checked voltage at the 5 pin connector at the pump. With the key on the wire in the center has battery voltage,but the 02 has only 7 volts with the key on. Seems to be a problem but not for sure. I really feel the pump is bad, but $400 is alot to guess with. I would appreciate any help I could get. Thanks
