What is the size of the lock nut on the crankshaft and where can I get the tool to remove it
Do you mean the bolt on the snout of the crankshaft that holds on the timing chain sprocket etc?
Or maybe the clutch lock nut? The outer nut is a normal hex nut, shouldn't be hard to figure out the size, I don't know and it is not given in the manual.
The inner nut is a special tool,
Lock nut wrench, 46 mm
07JMA-MN50100
07JMA-MN50100
I made one of the special sockets. It is ugly but it works OK. :)
