1 - 2 of 2 Posts
hello pal, been doing alot of riding, well another question, this what i have now, running dyna beads, nitrogen, kerk fron billet fork brace tires have mininual cupping have 12k miles on them, wanting to upgrade front end and put in some progressive springs, any ideas, and how easy is it to service the shocks and while apart i will put in a new front bearing, any help would be needed thanks Huck
Senior Guru
The shock at the rear is easy to get at under the right saddlebag. All you can do with that is refill with oil. The front wheel bearing is easy to do, and pulling the wheel to do the job is about the same as for the Gl1500.
1 - 2 of 2 Posts
