Steve,Okay thanks.
I appreciate you getting back to me.![]()
Steve,
when someone goes to great lengths to help you, we expect that you will get access to a PC and READ the information.
it is not our job to extract every tid bit of info and feed it to you.
Thanks for the pic Mike. Just the other day the wife asked how I know which is pin 19. I said I dont know, it might be marked so. The picture is self-explanatory
This happened to a friend of a friend. When he tried to install the new one it damaged the whole unit and he had to replace the entire thing which cost about $1800. It turns out that the number of the LCD unit he bought from that same company was not the same number that came out of the original unit. If those numbers do not match this is what happens.I just replaced the LCD display on my GL1800 with a so-called universal replacement.
I installed it perfectly, cables were in the right way, etc..
Now all I get on the LCD is a white blank lit screen.
I believe the video board got damaged as the new LCD screen might not have been compatible with this bike.
Now I can't see my odometer, radio stations or the GPS.
What I did for now is insert a Garmin unit into the cavity as you can see in this photo I've attached here.
Has anyone else run into this problem?
I need help badly.
I've added a second photo.
This is the new LCD unit I purchased online.
(No refunds BTW).
Thanks. (Sad Steve, Toronto, Canada) View attachment 330056
I don't know what to do now.This happened to a friend of a friend. When he tried to install the new one it damaged the whole unit and he had to replace the entire thing which cost about $1800. It turns out that the number of the LCD unit he bought from that same company was not the same number that came out of the original unit. If those numbers do not match this is what happens.
Thank you Peter for the information.Not some of the transistors. Its a precise one. And the thread informs you where to buy it
You might have everything fixed for under $100.00 But you have to read the entire thread.
So to make it simple : you replaced the screen with one that was not EXACTELY the same as the original despite what the label or seller said
.If you'd have cut or disconnected pin 19 everything would have been great, and you'd have had a working screen.
But you didn't know that and by installing the new screen you burned a specific transistor.
To fix your problem you have to replace that SPECIFIC transistor with one equivalent. The equivalents are provided in the THREAD.
After the transistor is replaced make sure pin 19 is disconnected or you'll burn the transistor again.
Good luck!
Over and out
Comprehension isn't a strong point with you is it? Because of the damaged board you now have,Thank you Peter for the information.
I will put back the original LCD screen so I won't need to cut any pins off...
I think that's playing it safe, don't you?
LOLThank you Peter for the information.
Great advice! Thanks so much....LOL
Very safe but you'll have a white screen since you already burned the transistor, Change the transistor and your old screen will be fine,
Put the new screen in and you'll burn the transistor again,
Repeat till you run out of cash.
I sure can use that TR1 transistor. Where can I buy one? I live in Canada....Comprehension isn't a strong point with you is it? Because of the damaged board you now have,
YOUR ORIGINAL SCREEN WILL NO LONGER WORK NOW!!! ALL YOU WILL GET IS A BLANK WHITE SCREEN!!!
YOU MUST REPAIR YOUR CIRCUIT BOARD BY REPLACING THE TR1 TRANSISTOR WITH AN ALTERNATE AS REPLACING THE ORIGINAL ONE DOES NOT SEEM TO BE AVAILABLE!!!
READ THAT THREAD AND YOU WILL FIND A FULLY WORKING SUBSTITUTE AND THEY EVEN TELL YOU WHERE TO BUY. AND IF YOU CAREFULLY READ, YOU MIGHT JUST FIND A POST WHERE SOMEONE WENT AND BOUGHT 10 OF THE ALTERNATES AND HAS OFFERED TO SEND TO THOSE IN NEED ONE FOR FREE!!!
ONCE YOU SUCCESSFULY REPLACE THE TR1 TRANSISTOR, YOU MUST MUST MUST MAKE SURE THAT THE RIBBON STRIP IS MODIFIED SO THAT PIN #19 CANNOT CONNECT TO EITHER THE BOARD OR YOUR NEW RAPLACEMENT SCREEN!!!
AKQ is a valid SMD code for a SOT-23-3L PNP transistor from TiP semiconductor. No idea if Digikey or Mouser ship to the Great White North.I took the thing apart again.
I found the transistor (TR1), but the numbers online aren't found anywhere... (AKQ 24 in this photo). Seems to be an invalid number!
Great information.AKQ is a valid SMD code for a SOT-23-3L PNP transistor from TiP semiconductor. No idea if Digikey or Mouser ship to the Great White North.
