I would like to put a brake light modulator on my new Wing and am curious as to which unit has the best reputation. I would like to include the LED trunk brake lights in the modulation. Which unit would be the best choice for this application and is it difficult to install? Any help would be appreciated. It is a 2010 GL 1800.
Where do you install the unit and how complicated is it to wire it in? Will I be able to wire it in to the LED upper trunk lights that are connected to the brake lights?
I looked at a couple when I got mine. Their all pretty simple to wire in. You have 1 live wire going to each side of your brake lights, cut both, use one line in to power the unit and tie the 2 wires out to the two wires out on the unit....... Done..... Takes about 10 minutes to install......... of course 20 minutes to take the seat off and put back on.....
