I'm fairly new to this forum but I have used this site to help make decisions regarding what to do with the front end of my Goldwing. I acquired the bike in July with 26k miles on the clock. First thing I noticed from the first ride on the bike is the front end was mostly garbage. Front suspension reacted harshly and sounded like a bucket of rocks when going over bumps. Steering felt like it needed to scrunch up before you'd get a reaction. You could not coast the bike with no hands unless you wanted a wobble and crash.
After some research my remedy was this:
-Race Tech 1.0 kg/mm springs & Gold valve (my weight: 215 lbs)
-Traxxion Dynamics fork brace
-Helibars
I had planned to replace the steering bearings with All Balls units but decided not to because they seemed fine - no notchiness or play; that was a mistake. I installed everything and the improvement was very noticeable but not yet to my liking. On rough roads the front end was still very flexy and sketchy if you hit a rough patch while in a turn broadcasting vibration thru the bars.
My next course of action was purchasing the Traxxion Dynamics triple clamp with the All Balls bearings. Took the front end apart again (I'm an expert at it now🤓) and installed it.
Result - Front end is now planted, absorbs bumps like it should, no feedback into the handle bars, and no wobble.
I'm satisfied with the front end now - it's what Honda should of supplied in the first place.
Upgrades in order of improvement (my opinion)
1) Race Tech spring & Gold Valve
2) Traxxion Dynamics Triple clamp w/bearings
3) Helibars
4) Traxxion fork brace
The Helibars helped stiffen up the front end but the main reason I installed them was to have the adjustability. Pricey but well worth it.
Roland
-Helibars
3) Helibars
Roland
