...and other strange behavior. Greetings from Middle Georgia. 2013 F6B, 146,000 miles. Bought new, I’ve ridden this bike in every State/Providence except for Labrador and Newfoundland. And above the Arctic Circle on 3 occasions. All reliably.
I park in the garage in front of my truck, on the center stand and in first gear. Last week, after it sat for a week, I did the usual mount it, roll off the center stand, duck walk it backwards, dismount to push it forward all the way out of the garage, then start it.
The strangeness started when duck walking backwards. It was in first, bike off, clutch pulled in and rolling backwards I had two spots where I had to push hard to get through. It felt like I was pushing through a flat spot on a tire, or a rotor momentarily hanging. The flat spot occurred twice in backing up about 10 feet. I’ll call this problem #1.
I dismounted, still in 1st and engine still off, I pushed forward for a couple of feet and all felt normal until an abrupt stop. So abrupt that I dropped the bike. At the time my thought was, dang it felt like someone stuck a steel rod in my transmission gears. That’s problem #2.
I proceeded outside the garage planning to take a spin around the yard now before getting on the road. It’s still in first gear, I start it, let all the way off the clutch and within about 3 feet the bike locked up and hit the ground faster than I could react. Big problem #3.
Now my confidence is shaken. I decide I need to try riding again in the field behind my house. Gingerly I rode in 1st and 2ed. Perfect, no problem at all. I immediately went to my Honda dealership. They ride it around the parking lot. It’s perfect.
I just returned from a week out of town and yesterday tried to recreate the problem by doing exactly what I did above when getting the bike out of the garage. None of the issues repeated themselves. I rode it around the yard and in the field. It’s perfect.
The bike is under Honda warranty until April. Honda would be proud of my preventive maintenance including annual brake and clutch flushes. The brake pads are Honda. The rear drive fluid is the correct spec and amount. Main oil is the correct spec with a Honda filter.
I would appreciate your ideas on what I should do next!
