Friday evening getting ready to leave work and the gold wing does not start at the touch of the start button. After dozens of attempts it finally does start and I ride the 26 miles home. Saturday morning I go out to check the bike again no start multiple times. Now I get my tester check the battery which shows good voltage but also shows no load when I press the start button. I'm questioning whether it is a relay or the start button. Narrow the search for the culprit I attempt to go through the start cycle without the key where I have to enter the code through the start button, by holding the button down for five seconds which should produce an audible beep and then go into program mode I never got a beep I cannot program I cannot punch in the numbers so I am thinking it is the start button in the right hand switch. Now I disassemble the switch get some spray lube and shoot it into the interior of that switch several times it begins to start intermittently but quite frequently.
Has anyone else seen heard or experienced a similar situation? I am in South Florida and have been riding in monsoon rains for about a week I am just wondering if the interior of that switch got wet and shorted out
