(1.) Air cut off valve, where is it located? and how many are there? (some say 1, and or 4 of them?
(2.) Bad miss firing on rt side (1and3) until warmed up, then smooths out? NOTE: it had the same problem before I changed-points,condenser,static and dynamic timed,and new belts?
(3.) Hard to start. If it will start just by choke its ok. However if thethrottle has to be used it will idle to low and hesitate on rt side (like a palpitation) and sounds like a gremlin eating metal...?
Ok guru's hit me! or shoot me or sumthin.....Thanks!
