1 - 9 of 9 Posts
Happy New Year All!
I obtained a set of used trunk and saddlebag trim. I was able to remove the old adhesive strips. Chrome cleaned up very well. The trim slats are quite narrow and no tape could be found that narrow. Every inch of the chrome had adhesive. To attempt to cut tape to fit this need seems to be too much of a task.
I'm looking for alternatives. Does anyone know of any spray adhesives that might work?
A search here also shows that many use clear silicone for emblems. I'm leaning toward this. Cleanup would not be tough.
All suggestions appreciated.
Still proud to be from...
psu
Please let justice prevail!
any chance you can post a pics of exactly what you are trying to mount up?
Yes.
This type of trim.
Just another ORF!
I highly doubt a 'spray adhesive' will hold for very long, if at all.
Here's the way I would tackle it.
Get the 3M high bond adhesive tape (holds very well!) and stick it on the back of the chrome trim pieces, after you have cleaned them with some rubbing alcohol. Then I would get a small/thin , sharp exacto knife and run that along the edges of the trim from the other side, when you have it laying on a cutting board, taking your time not to nick the trim.
Then clean the area where they are to be applied with alcohol as well, peel the backing from the tapeand then apply.
Ya ... a lot of finicky work, butit'll stick.
+ what Dusty say's
Wilf
Senior Guru
Don't use silicone, it's very hard to remove. "No more nails" tape is as good as 3M and probably easier to find.
Also warm the trim up with a heat gun gently so it is warm to touch.
Stick tape to the trim first, let it cure for 24 hours.
Then stick trim to saddle bags, again heating it all up so its warm to touch.
Monkey with a Football
Biggest problem I've had with that trim is that if it isn't perfectly relaxed to fit the lens exactly, no tape or adhesive will hold it down.
Go with the 3M VHB adhesive. You will need to get it on ebay or at a professional auto body supply house.
Bad part is you are looking at $60 - $100 a roll and you are still going to have to cut strips of it. I use scissors and cut very slowly.
You really don't need the adhesive if you accurately re-shape the metal to fit the lens. The tape just holds it there until you get the lens drilled and screws applied.
Bob Cassel
3M spray trim adhesive will stick anything to anything.
3M liquid trim adhesive will work too, we have always called it "Monkey Snot" because it sticks to everything and you can't ever seem to be rid of it.
1 - 9 of 9 Posts
