60K service
1488 Views 11 Replies 7 Participants Last post by  mwhit1500
So my GL1500 is getting close to 60k miles. what basic service should i get done? plugs? wires? synch carbs? fuel and air fliters?
what about brake fluid, clutch fluid, coolant?
ken k
1 - 12 of 12 Posts
Buy or download a manual.
Timing belts top of the list. 60k miles might not be a lot, but the age of them would be more critical unless you know they were replaced already.
timing belt eh, sounds expensive! Anyone have an idea of cost? I know, it would be cheaper than a new engine when it breaks right....
k
k
Yes it was answered on the other post you made with this question.
Tubabone,
I sent you a PM. I may be able to help you with your service work. Check your PM for info.
you should get the timing belt change i done it myself but if not mech incline i think you should do it at a shop a dealer maybe to much
Besides installing new timing belts and checking your tensioners, your brake/clutch/rear drivefluid should be replaced every 2 years , along with a rad flush and new non-silicate coolant every 3 years. Inspect/replace your air filter and install a new fuel/sub and cruise element filter, if they haven't been done recently. Inspect/replace brake pads
tubabone
Did you ever get my PM for possible help with your service work?
mwhit1500
G
Timing belts are about 25 or 26 dollars a peice.
You will need two.
Takes about 2 hours to change them.
I would recomend gates belts.
Plugs, air, and fuel filters.
Carb sinc also.
Good luck
TOMMY
Hello mwhit1500,
Yes I did get your message. i apologize for not getting back to you. I have aa friend here near Reading who is helping.
Thansk for the offer, again I apologize for not getting back to you.
ken k
mwhit1500 wrote:
tubabone
mwhit1500
No problem, great to hear you are getting the service taken care of with help from a friend. ;) Happy riding, Mike
1 - 12 of 12 Posts
