1 - 3 of 3 Posts
Hi again,
I tried this on the parts for sale/wanted forum but got no replies so thought I'd try over here.
I'm after a couple of slides and caps to suit model 755A carbs. Mine are completely stuffed, broken in half. I've managed to source a couple from within Australia but can only get the later '76 model units from elsewhere and I needtwo more.
Correct part number is 16022-371-004 if that helps.
Even if you don't have any I'd appreciate suggestions of where I might be able to get them.
Many thanks,
Rob
Senior Guru
Unless I'm mistaken Rob, the 76 carbs were the most troublesome. You could be better off buying a complete used set, cheaper in the long run.
Thanks GW for the reply. I think I've not managed to get across what I'm after. I'm looking for slides for '75 model carbs but all I seem to be able to get is '76 model ones. I'd like to get the original '75s if I can.
Cheers
1 - 3 of 3 Posts
