Since it was running when you took it to him it's not likely to need the carbs cleaned. Just get them adjusted right. Set all 4 mixture screws 2 turns out then try to get the idle speed set. They may need synchronized also.
yeah and according to the PO they were cleaned about a year ago. as far as doing the adjustments, should i go ahead and get the valve stems done first before digging in to the carbs? the compression was a little lowSince it was running when you took it to him it's not likely to need the carbs cleaned. Just get them adjusted right. Set all 4 mixture screws 2 turns out then try to get the idle speed set. They may need synchronized also.
should i also be taking a look at the fuel filter? or fuel pump?Since it was running when you took it to him it's not likely to need the carbs cleaned. Just get them adjusted right. Set all 4 mixture screws 2 turns out then try to get the idle speed set. They may need synchronized also.
found notes from the PO and it says Brandy WineHope you get it running, pretty bike. Do you know the color ? It's red I know but which red? I have one I'm about to paint and loved that color. Sounds like it may be running out of gas for several reasons. Rusty tank, bad gas, petcock problem, fuel pump or carbs. Good luck.![]()
Doesn't matter and the valve seals have nothing to do with compression.yeah and according to the PO they were cleaned about a year ago. as far as doing the adjustments, should i go ahead and get the valve stems done first before digging in to the carbs? the compression was a little low
Of course.should i also be taking a look at the fuel filter? or fuel pump?
I'm sorry but carb cleaner or whatever through the air box does absolutely nothing. And please don't try to tighten valve cover screws, they only go in so far and have a shoulder to stop them. Tightening will only result in breaking them or stripping the threads.One more thing, try running sea foam through gas or carb cleaner through airbox. I prefer sea foam, like carb cleaner, it works to clear out venturies that may have gotten a little gummy over winter, but in my own opinion i feel its safer than carb cleaner.
First do everything Dennis and Bike suggested. He is right on. Everything that's happening to you, especially the shop, is part of the learning curve and experience. Biker's Creed, right? After a while you won't want anyone touching your bike. And that's a really nice bike you've got there.yeah i guess thats what i get for trying to help a small business. since this is my first carbed bike i know 0 about carbs. if i am going to be removing and cleaning the carbs, am i going to be doing a rebuild of them or just opening them and seeing if there is anything stuck and just leaving the original parts in there?
I’m going to be checking fuel pump, filter and petcock once I finish swapping out the Valve Stems. Should be done with that this weekend. I’m really hoping it’s just the filter or something like that and not anything on the carbs. I just don’t think that the carbs are at issue since it was running before dropping it off. I’m taking care of the stems first as the right side had sputtering exhaust so new stems, oil and spark plugsFirst do everything Dennis and Bike suggested. He is right on. Everything that's happening to you, especially the shop, is part of the learning curve and experience. Biker's Creed, right? After a while you won't want anyone touching your bike. And that's a really nice bike you've got there.
Nice thanks for the relief. The belts are basically new as the PO swapped them 8 months ago and tension was perfectThats the way ive always done them but i would fit new belts and check tensioners
Every video I have seen has had them removing the cams but then I read one where he did not so when I couldn’t remove them cam I just went ahead and removed it all together. Looking back, yeah it makes no sense in removing them.Not sure why you would remove the cams but make sure to put them back close to alignment so you don't have to turn them far and risk bending a valve.
