21 - 22 of 22 Posts
But the shifter would still move.
I thought of that but I wasn't sure if he meant it didn't shift or locked up tight so I took a shot. I guess I will ask now if you look where the shifter shaft goes in to the engine does it move slightly when you push or pull on the shifter lever? It won't turn very much at all but it will move slightly.
Discussion Starter #22
With a normal shift the shifter moves up/down approximately 1in. When the problem occurs the shifter moves only 1/4 in. then stops.
Guys I am stepping away from this for a while. Tired of working on it for now. When I get back to it I will pull the front cover and inspect. Thanks to all.
21 - 22 of 22 Posts
