Charged up battery with 2 amp charger as hadn't started
in a month. Charger said full and ok. But no power at all.
Checked the main 30 amp fuse and other fuses in the
fuse box, all ok. No click, lights, nothing. Don't
ride much but start on a regular basis, never had this
before.
check all the battery connections?
Test the battery with a multi meter or pull it and go to autozone etc and have them test it. Sounds like a dead cell maybe.
What part of San Diego are you in?
I cleaned and tightened the battery post connections, are
there others I should check?
Stu, I was thinking of jumping with a car battery to test
battery. Location is next to you, just off 78 and
El Camino. Used to go to CMA events in Escondido, member
nationally since 1982.
I sent you my number by pm
Only jump from car not running: engine off only.
