I recently purchased a $500 wing with the manifold conversion and it has the
solex 34 pict 3 carb on it obviously not runing but what really got me confused is that I can't find the terminals or connections for the electric choke, please If anyone has answers please let me know thank you very much in advance.
323289
323290
02 GL1800 w/Auto Pilot
First,
Welcome to the forum, glad to have you here.
2nd, I'm not familiar with that carburetor, but do know that the heater spring to open/close the choke is mounted to the side of the carb. It is possible, that part of the carb was not installed ?
The terminal, IIRC, is just a single tab for a wire that goes to the Ignition switch.
Here are some links that I found:
Thank you guys
Just for the record I check the float side of the tank an it says solex 34 pict 3 I tried to take a picture but it doesn't show the detail
323292
Does it have an electrical tab type terminal coming out of the choke stove? If so just run a wire that is hot with the key.
323295
