Hello all again,
just put air cleaner back on before riding, started, died couple times seemed weird, started again, revved it up and got to end of drive when died again. pushed back home cause when switch on no red light/neutral light and hitting started switch did nothing. Found main fuse burnt in two. just for grins if put a ink pen spring in place of the main fuse, simply turned on switch and it burnt in two.
my guess would be that air cleaner box shorted out against the resistor on right coil.
considering I just got it running great before this,
Should I assume that there is a short that caused main fuse to burn out??
Hello all again,
