1 - 9 of 9 Posts
My 78 wing wont steer straight ahead,the whole time I`m riding I have to pull back on the right side of thehandle bar.If I ease my grip on the right side and lean to theright the bike will go a little straighter.
After checking the axle,wheel,forks and clamps for correct alignment I`m starting to wonder if its me and not the bike that is the problem.
Any help would begreatly appreciated as I love riding this bike.
This site is a great find
Cheerskiwikid
Hi kiwikid. It sounds like you have checked the main items. I'd suggest checking the wheel bearings next and also the steering head bearings for play. Also check the frame for kinks in case the bike has ever been crashed and teh frame bent as that can lead to odd riding experiences!:waving:
like the others check the steering head bearings, mine wore a rough spot and had to be replaced. you can put the bike on the center stand, jack up the front end and feel how the steering goes through the range of motion.
Cheerskiwikid
:waving:Welcome to the BEST GOLDWING WEBSITE in the Known World!:waving:
You didn't mention whether this bike has a fairing or saddlebags. If it does is there any chance the fairing is shifted a bit or there's any unbalanced weight in the fairing or saddlebag? If you do have saddlebags and/or a fairing have you tried the bike without them.
How about the fork springs and swing arm pivots. It would seem that if there's any significant difference in the fork springs or other fork internals this might be a problem.Slop in the swing arm pivots could create a problem.
:waving::15red::waving:
1 - 9 of 9 Posts
