Hey all I am returning my recent purchased 78 GL1000 back to standard. I have most everything now except the front turn mounting studs to the forks.
Any way to the tech. Why do you think there are two sets of turn signal wire plugs in the head lite bucket.
One set seems to come from the instrument cluster and one comes from the large electric main harness. They are the lite blue and a orange female end with clear and half white insulating boot, and a brown female end with clear insulating boot, from the main harness. And from the instrument cluster is a lite blue and orange female with clear insulating boots on them.
I see also the small speaker -buzzer rubber mounted to the inside left triple tree has three wires brown gray and white with male ends ??? any ideas do they go to the extra turn wires to buzz the turn signal buzzer ? Their are a couple other White with green line and a gray/red as well extra ..
I might have figured it out while writing this to you guys..
Well please share your thoughts
Also does anybody have Dyna electronic Ignition ? Mine does, and an a friend said that the resistor on top of the coils should be bypassed if you install Dyna also any thoughts..
