1979 - 75 GL 1000 Cafe style
79 OEM carb stack on 75 GL1000 engine. About to sync carbs any tips to on what to favor, richer vs leaner idle mixture screw, 79 is 2 turns 75 calls for less? All other prerequisites have been performed, timing, compression test, valve lash set to 75 OEM specs. Currently starts easily, runs, comes up to temp with zero issues, warm idles at 1100 ish.
I can provide you with 2 pages of the GL 1000 Honda Shop Manual where all work is explained in detail.
Good luck.
Mario
much appreciated, think i will tack this weekend if the Boss doesn't have any higher priority tasks scheduled.
Check this out. I have one somewhat like this. On youtube several are listed there. I bet you will find one for your needs,
Gents first try at this, ever, new ebay gauge set, looks like i got it right?
Unless anyone sees an issue, really not sure what im looking at to tell the truth, just followed step by step, but it runs xcllnt.
pre sync pic
323609
post syn pics
323610
If your happy that's all that matters. Looks like a job well done.
