When I am out riding I normally am getting close 14 volts as I believe I should be however when the fan goes on that goes below 12 down to about 11 and when the fan goes off it slowly goes back up to close to 14 should it do that or am I looking at some repair or replacement of charging components.
Verify the voltages with a hand held meter. The voltage "swing" seems right. The values are too low. Pull the pod and see how much voltage is being supplied to the meter and if it's the same as battery voltage.
Yes, and it could be the meter is tied into the same circuit as the fan and there is a bad connection causing it to show lower than actual voltage.
charging question
Thanks for the info plan to check later today, now on another note looks like I've got leaking front fork seals so I'm going to have to replace them.
