under the left side false tank cover on the 78. Idont know about the 79. jb
Same spot
I have a confession to make. It is probably obvious to all of you that I am a novice. I have been having this voltage problem for several weeks. Bike was running good but the volts were high. I went to a motorcycle graveyard yesterday and bought a voltage regulator. got home, read the post telling me where it was located and took the false panel off. >>Dumb alert
When I took the side off I noticed that the voltage regulator connector had vibrated loose. Plugged it back in and low and behold the voltage meter shows between 13.5 and 15.5.
Advice for newbies. check to obvious first.
