Ok I should have said I have 4 each of these O rings I guess 1 for each of the carbs? But were do the go? I will also add a picture with a dime in it so you might be abel to tell more about it.
Thanks for the help
Now ask a mod to merge this thread with the other one to keep everything in one place.
The big one is likely for the intake runner between the runner & intake on the cylinder head.
When you took everything apart did you match up & replace the O rings as you went along. If you did maybe just to many O rings. If you had the float strainer ( can't think of right name ) out it may have gone there. If you never took the strainer out then that would explain why you have it left over.
If you get stuck go to the nakedgoldwing site & post your qestion & picture. You should get an answer, also you could send your question to Randke.
Thanks for all the help. I found out that the large O ring is for the manifolds and the small ones are for the plastic cv slide top,
Thanks again
Bailbob
