I have been rebuilding my 81 GL1100 over the winter.
:shock:
Repair and upgrade list:
Many of these are complete and I am down to the last few. One of those is the Front Forks. I have two sets of forks and am trying to do a rebuild using the best parts from both sets.
My questions have to do with these. I have ordered a new set of progressive springs, new seals and rings and new dust covers. In taking the forks apart both sets had the same springs inside. What appear to be a form of progressive spring although they are a bit shorter than the new ones I ordered and a much shorter set of what appears to be standard type springs (equal spacing between the rings). Is this right? I thought there would only be a single spring in each fork.
Also, I had a devel of a time getting the o-rings out but finally got them out after buying a better set of o-ring pliers. However, I cannot get the old seals out now. I have tried over and over to "pop" them out by sliding the tubes out as hard as I can but they refuse to budge.
HELP!! :clapper: :? :headbanger:
:shock:
- Replace and rebuild Front Forks
- Fix non-functioning Cooling Fan
- Replace Timing Belts
- Replace Valve Covers and Gaskets
- Replace Spark Plugs (Iridium, plugs)
- Replace Oil and Filter
- Replace Coolant
- Replace Air Filter
- Replace Fuel Filter
- Replace Windshield Accent with Chrome
- Add Wind Wings to Windshield
- Add Side Wind Wings
- Replace Side Engine Covers
- Change Clarion I System out for a Clarion II with Intercom and CB
- Add Headsets to Helmets
- Add on-board Compressor for adjusting Forks and Shocks
- Replace worn out Throttle Lock
- Clean and polish all Chrome
- Repair cracked Fairing
- Repaint and add new Chrome Parts and Accents
