I swapped my stock mufflers for a set of aftermarket mufflers from j.c. whitney. Three weeks later the bike started running rough at slower speeds (30-40 mph) and was backfiring a little on the left side so I took my bike to the shop to see about getting the carbs cleaned and re-adjusted or find out what the problem was and they said I could only use stock mufflers.I'm sure I'm not the first to change mufflers.Has anyone else changed out their mufflers and did you have any problems,Thanks for any help,Randy
The Irish Crew
Randy if the mufflers were the problem then the problem would have started as soon as you rode the bike first time after fitting them.
Those mufflers from JC get good write ups from GL1100 users. No real need to make any carb mods either. Perhaps a slight flooding problem (dirt in carb).
Thanks for the quick reply.I thought the mechanic was trying to yank my chain.Appreciate all the help to you and Jason who also replied.
