What would cause the bike to keep accelerating for a few seconds after throttle is closed? Confirmed that cables are running freely and not sticking on. Choke isoperating and cable not sticking.
All jets have been replaced with new and same size. Float heights are spot on. Air cut-off valves (diaghrams) are on the firm side (leathery texture)but not split or cracked. (got a set ordered). the carbs are all balance pretty equally.
the bike is in my local workshop at the moment. The mechanics are not wing experts and i'm kinda guiding them best I can but they do know their bikes.I'm asking thishere to draw on your experience for them.
Workshop have stripped carbs again and flushed, cleaned and refitted. Same symptoms I found and that is - running on 2 cylinders(right hand pair as you sit on bike). Chugs a bit on tickover and take off then the other 2 LHS cylindersseem to kick in and you feel the power surge. The scary thing is when you back off the throttle after accelerating hard, the engine is still pulling like a train as if the throttle is still on. The engine takes a few seconds for revs to back off.
I've got another set of carbswhich are pretty dirty and are gunged up inside. The diaghrams are soft and rubbery as they should be.
The workshop are going toclean, set up and fit these carbs and see how the bike runs.
Hasanyone experienced same symptoms and can offer some advice?
Cheers GW
Cheers GW
