i sure hope you turned motor over by hand before using starter. fully charge battery, make sure getting fuel.
Also, hook the battery to a low amp charger, 2 amps or less.You don't want to boil the electrolyte.Dave: I think I would pull the timing belt covers and check belt alignment before I would try starting again. Also check static timing (rotate by hand) it's easier to see marks that way.
