just finished putting the rebuilt carbs on the bike and attempted to start it. I have not put the whole aircleaner assembly on yet as I wanted to at least hear it start first. What I noticed was gas pumping into the plenum assembly from the number 3 carb. Any thoughts on this.
pull the carbs back out
put them on a bench and get some sort of fuel pump and fill them with fuel, this could also be done with a gravity flow setup
then take a screwdriver and tap the offending carb with the handle and see if it quits leaking or if you need to take them back apart
Banned
if it sticks once....
Floats needle valve not shutting the fuel down for some reason.
very true, if i stuck once i wouldnt put them back in, i would have to find out why and which one
