After removing the false tank I found that the reservoir was completely emptied. Then I removed the radiator cap and I found what I believe to be the problem. It looks like one of the flanges that the cap uses to stay on is bent down a little. It is where the drip is in this picture. It can be moved easily back into place I would assume. The cap was not making a good seal.
What I think has happened is that the entire contents of the reservoir have emptied to the ground through what would have been a gap between the radiator fill lip and the rubber gasket on the radiator cap.
