83GoldWinger wrote:
Wichita Scorpion wrote:
Hey 83GoldWinger, according to the schematic, the only thing connected through the accessory fuse is the 1.7 wattIllumination lamp for the Pressure Meter.
The Pump Switch and the Pump Motorreceive 12 volts fromthe 5 Amp Park fuse.
:waving:
Trace the wire from the negative accessory terminal and you will see that it also goes to the pump.
:waving:Yep, you are correct, it does go to the pump. The accessory negative screw terminal is the common or ground. You can short the accessory negative terminal to the frame of the bike and nothing will happen.
The common or ground for the switch/pump/illumination light is connected to the negative accessory terminal with a Green wire. Green is the color for common or ground throughout the wiring harness on the bike.
The accessory plus screw terminal at the accessory fuse is 12 volt power. According to the Honda Manual schematic, the only thing connected to the accessory plus terminal is the Illumination Light (Brown/White strip wire) for the Pressure Meter. An overload on the accessory plus terminal side of the fuse is the only thing that could blow the 15 amp accessory fuse.
The pump switch and the pump gets 12 volts from the 5 amp Park fuse.
Hope this clarify's things some.:baffled:
