1 - 2 of 2 Posts
today I filled my bike up with gas but the guage only went to just over a half. never done this before. should i take the fuel sending unit out and check it or just let it go and hope it starts working properly again? has this happend to anyone out there? what would you do?
Is the temperature guage reading normally? If it is also reading low the likely culprit is the 7V regulator.
Disconnect the wire at the sender unit and ground it against the frame. The guage should peg full.
All test after this require taking the sender out of the tank so see how you go with the above.
1 - 2 of 2 Posts
