Hi everyone.
I recently have replaced my seat on my 82 Aspencade. It’s a really good Saddlemen seat. I am a good size guy and like to have my seat back and with this new seat my wife does not have much room back there for her to enjoy this new seat too. Were not the “Ken and Barbie” body types.
I did a couple of searches on “Trunk Relocation” and came up with a few ideas. I know that I could have purchased one for $50.00 or so but I would rather make one myself as I can get exactly the fit I am looking for and I enjoy doing the work.
This whole project cost me a total of $10.00 for the steel bar and SS nuts and bolts. Build time was about 3 hours. Not including the drying of the paint.
It is important for me to say that I did not come up with this particular idea. From what I can tell “Lil Pete” originally came up with the idea and then “Maddog355” put it into words with limited pictures. In his article HERE he says “Hopefully one of the members will take some pics and do a step by step of this for theFAQ section as it is a must on the 1100s.”.
So here I am as I am rolling this project out. I hope you like it.
As a reference, this is what we are starting with. We will be removing:
(1) – Six rubber feet. The 4 thin ones that are horizontal are taped in place and the 2 thicker vertical ones have two rubber tips inserted through the trunk. Remove them carefully by prying back on them. Remove the old tape from the feet and trunk. Cut the two rubber insert tabs off the other two feet flush with the feet. Clean them and set them aside. You will need them later.
(2) - Removing the Trunk Latch Pins. There is a nut inside the trunk. They are probably greasy. Clean them and set them aside as well.
(3) – Remove the two Trunk Latching Plates from the trunk. There are 4 nuts and washers inside the trunk for each side. You might as well clean these up too and set them aside.
Take this time to give the belly of the trunk a good cleaning. You will be using two face foam tape here and a clean surface is a must.
Hi everyone.
