I just acquired a set of floor boards "mc enterprises" for my GL1100. The brake pedal rests right on top of floorboard......Before I start fabricating and making it work.....what is the correct way to install brake pedal for it to work.....do I bend it, cut it, unscrew it, move it, curse it, or buy another piece..........
First make sure it is up far enough on the splines of the pivot shaft. You may be able to move it up a few notches. Remove the retaining bolt or clevis pin?(been a while since last on one of the 1100) pull off the of the spline shaft and move upward if possible.
I have an idea---why don't I read something----and use the brake pedal height adjustment screw---------I"M SO STUPID
You may find you need something similar to the stud shown in the picture to put your heel on when using the brake pedal.
You may also want to make sure floorboards are for you first. Many riders, particularly the "in-seam challenged" fine that floorboards push their anckles/stance out wide when stopped at a red light. So wide that they condider it unsafe or even painful.
