1 - 3 of 3 Posts
can anyone tell me how to set the ft wheel bearing? I took the ft wheel off to fix the gear box for the speedo. but is there a pre set for the ft wheel like a car or is there a setting in inch pounds.
There is no adjustment on the bearings. They are sealed ball bearings pressed into the wheel. You just slip the axle through, add the speedometer drive and spacers and bolt it up to the forks.
Your question is unclear to me. Do you have to preset the bearings? No. You do have to torque the axle bolt and the axle pinch bolts.
1 - 3 of 3 Posts
