1 - 14 of 14 Posts
can you see the filter in the tank for the reserve if you pull off the fuel meter float? Mine is clogged and would love to remove it.
It's a screen and I believe you can get to it through the gauge opening.
What leads you to believe that it's clogged?
The main filter isn't in the tank. That's just a screen as mentioned and it can be blown clean with tank empty and reversed back through the petcock with an air hose, fuel gauge removed.
Remove the fuel line and switch the petcock to both main and reserve, blow out the crud, then clean it up with a wet/dry vac through the fuel gauge hole, vacuum out the whole tank to be sure you get it all.
i just bought a 1/2 gal. Black and Decker wet/dry Vac at Walmart for under 30 bucks. Runs great and comes with a wall hanger setup.
I meant screen, but anyways I dont get any fuel from the reserve. It has never worked since I had the bike. Ive run out of fuel three times now and had to push the bike to nearest gas station. Luckily all three times I was close to a station as I knew it was time for gas. But let me tell you how much it sucks to push that big a** bike. Can it get so clogged that no fuel comes out?
Other side of the pond
The fuel tap itself could be the problem Wayne.
There is a tube from the screen to the selector valve that could be plugged
There is 2 screens in the tank. Remove petcock first to see if you can get air thru it.If open remove seat and sending unit from tank. See if you can blow air thru both fuel line. If one is blocked use old speedometer and lube[oil] in a drill to clear the lines. Nice and slow on the drill speed.
Discussion Starter · #8 ·
thanks for the hints guys.. Its not the petcock, tried the air, didnt work. I will try the cable in a drill my next day off and lrt you know how it goes
that works. but watch which way the cable is wound and turn it that way. the first bend is hard to make. the cable wanted to wrap it self up on its self.
Discussion Starter · #10 ·
sorry. double click
Discussion Starter · #11 ·
with the cable, you cut the end off i would think, right? or do you put end in that would feed into the speedo without cutting?
i used a broken cable with no end on it. put it in first.
Discussion Starter · #14 ·
Ok thanks guys... I will try it.
1 - 14 of 14 Posts
