yeah......... the inside oring keeps the oil sealed and the larger diameter outside oring seals off the anti-freeze. Tha front engine cover has to come off, there are three bolts the hold the pump on the inside of the cover. If you take the water pump cover off and wiggle the impeller, if there is any movement, your pump is shot. There is a complete gasket set available that covers all the bits you will need to do the job. gasket set is 24$.pump is 107$ at westernhonda.com, It does not include the mechanical seal around the oil pump shaft, you should replace that seal as well.
