1 - 2 of 2 Posts
Clarion ll radio system, it takes about 30 seconds for radio to start playing music when I first turn it on....is this normal?? also I want to hook up radio on a toggle switch so I can use it with key off....what color is the wire that goes to memory...(it should always be hot)
Hi DKL, it should not take 30 seconds for the radio to come on. It is instant on. There are a bunch of connectors to clean but that is where I would start. Past that the problem will be in the electronics and Sierra Electronics will be able to help with that unless you want to start swapping pieces.
As for the putting the radio on a toggle switch, the red wire is hot all the time. I wouldn't go that route myself because of the liklihood that the radio could be left on either by my own forgetfulness or someone turning it on when I didn't know. The radio will play in the ACC position without the lights being on if that is what you want to accomplish.
1 - 2 of 2 Posts
