Can I use a 80 gl1100 tire and rimon a 83 gl1100 I have a new tire on my wrecked 80 it is a 19" instead ob a 18" I know to watch for the clearance i'm juat wondering if there is anything else to watch or will give me problems Thanks BB
UPDATE The tire swap went perfect only had to change the speedo gear housing due to the screw that holds the cable is in a different location Thanks everyone BB
I think you can if the rotors fit. but not sure because of the rotors. but most things do work from 80-83
It should fit right on with no problem. If your 83 were an aspencade you would have to change the rotors.
new 2 forum ,i took one from a 79 and put it on my 83 interstate it bolted right up on brakes , but the spedo gear was different spedo wasnt working anyway so put the 79 spedo on also. i think u can use your gear on the 83 if it is different
