I put my freshly charged battery in the bike, turned on the key, hit the start button, it turned over then lost all electrical. Everything. I checked the kill switch andmade sure the battery was right. I broke out the meter and I have correct voltage at the battery and out of the old dogbone. I looked at the wrong schematic and made the assumption the ignition switch died. Not good news on the 83A. I am in the process of tearing the front end off.
Last night, I realized my mistake on the schematic and I see now that the 83A was unique and went through the starter relay first. If I am reading it correctly, however, it seems to be a straight pass through controlled by the fuse and would not cause power loss to everything if the relay failed.
When I get to the igniton plug I think I should be showing the correct voltage between the hot and ground which would verify switch failure. Am I right about the relay and does this sound about right to you guys? dj
