83 ASPENCADE 1100 SPEEDOMETER PROBLEM
1610 Views 14 Replies 10 Participants Last post by  sandcastcb750
Have a 83 ASPENCADE 1100 and the speedometer does not work. shows a constant "0" but the tach works and the odometer does work also.. any suggestions?
1 - 15 of 15 Posts
Welcome from across the state!:waving:
Probably have a bad speed sensor on the front wheel.:action:
:coollep:The Guru's will be along soon, but Have to ask
1. Has it been acting up-such as the needle jumping instead of running smoothly ?
2. Has the speedo cable come loose(this happen on my 82 Asspy)
There are a number of possibilities as I said the Guru's will be along shortly
:coollep::11brown:Winger 82
2. Has the speedo cable come loose (this happen on my 82 Asspy)
Hey W 82,
If its an '83 Aspy, it should have a digital dash. Mine does.;)
Does it have a digital dash, P29150?
:coollep:Sorry I stand corrected, Just going by word of mouth that the speedo's off of the 83's were interchangable with the 82 Asspy.
As I said the Guru's will be by shortly to fix us rookie's mistakes.
:11brown:Winger 82
The speedometer and odometer run off the same sensor so that tells us the speed sensor on the front wheel is working. Troubleshooting in the manual does not deal with this situation but an educated guess is the speedometer LCD unit is bad or there is a problem in the circuit board. May times I have been able to repair circuit boards by examining them closely for cracked solder joints and remelting the solder on cracked ones. My eyes don't allow much of this anymore unfortunately.
Yes it does have a digital dash...think this is the first year that they came with them. I found another dash to replace it with but the only problem is that the milage is way off....I have 27K orig. miles which match the title but the new dash shows 88K miles. not sure what to do about that too...
That's dashed awkward!
Sensor, or the gear on the hub.
Can't be the gear, the odometer still works.
Does the Aspencade use an electronic speed sensor or still use the cable type? My Interstate has the analog gauges so I'm just wondering.
Electronic
;)this also would be my 2 cents worth. ;)
I missed the odometer part, so, probably it the electronic readout. I wonder if it is the LCD as the zero is there. I have seen LCD bleed black.
A replacement dash is probably in order if the odometer works.
Somewhat similar as the post heading, but slightly different symptoms.
This weekend I replaced the fork seals and all the other small parts on my '83 Aspencade. (Digital dash) When all was said and done and I test rode it, everything seemed fine. I left Monday for my work week (100 mile ride where I stay for the week... home on weekends) and I realized my trip meter got to .8 miles. Odometer is NOT working Speedo says zero. Yes, my set screw had fallen out on the speedo sensor.
I have replaced the screw. I am sure it is seated all the way down now. I noticed that when I had the sensor removed and spun the front wheel, the little tab inside did not turn... It sorta "jumped" I fear I may have broken the gear or something, but I am not sure exactly how it works. Anyway, even with the sensor and cable well seated, still no joy.
Is there a replaceable part? I have personally put 250,000 miles on my bike and it still runs strong... I just don't like driving around guessing at my speed.
I think the GL1200 Aspencade sensor parts are the same, but maybe somebody else knows better.
1 - 15 of 15 Posts
