I have and 83 aspencade that I would like to put an engine from a 82 interstate on. Aspencade has a 6 wire harness out of the front of engine 82 interstate has a harness with fewer wires will these interchange?
Thanks for any advice you can give me.
Be aware you are going to a lower ratio transmission now. So your RPMs will be quite noticeably higher at freeway speeds than they used to be.
You're putting an Interstate into an Aspencade?
The six wire neutral switch is for the gear readout on your digital dash, as previously stated. Since you'll have it out, you'll need to pull the front cover and find out if there is a provision for the Aspy neutral switch on the shift drum assy.
