1 - 13 of 13 Posts
Is it the same motor for 83 models?
Yes
80 to 83 all the same motor and the 75-79's will fit too..in a 1100 frame.
But the transmission gearing is different. 1200 engines will also fit the 1100 frame.
big PIA
Will not pose a prob, just slightly different gearing is all. If you install 1200 in the 1100 frame the best bet would be to use an 84 1200 engine, I know because I have done that already, 85 and newer have the ignition is on front of engine and 84 is on rear like the 1100's
Will this pose any issues when installing a new engine in my 83 Interstate?
The 80-81s are somewhat lower geared, the 82 is closer but still a little lower than the 83.
There is a gear position sensor for the neutral light only on the Interstate, in it's place on the Aspencade motor is a gear position sensor for all the gears, not just neutral.
There is that difference in the two '83 motors.
The 83 interstate has an OD (5th gear) light also.
Forgot about that purple light. It has been a while since I have ridden my '83.
I doubt I ever will, I gotta get rid of all 4 of my GL1100's sitting around my old house. My '97 is my bike from here on out.
Discussion Starter #11
Sounds like I will have no issues using an 83 Aspencade motor, thanks.
My question now is how the sensor will be different. In other words, will it affect anything on the instrument panel? Should I change that out too?
No, it will plug in and work as is.
Any "standard" model among your 4 GL1100`s ? , - i could help you "get rid of . LOL
1 - 13 of 13 Posts
