Most likely standard size, if oversize pistons are in use they will usually be stamped on the top as to what size over.
Only true way to know for certain is to measure the bore.
ok heres what the honda manule says ,Thx DriverRider,
thought I Was looking more for the gap where the ring sets in the piston grove that space between the top of the ring and the piston grove, maybe they are all the same, As far as the size of the piston and the bore, they are all stock,
Unless it is a Honda MC thing there are no oversize ring to ring land clearances piston rings for height. There is only oversize rings for bore diameter. If you have standard pistons you order standard rings and check the end gap in bore.Ya that what I read WDA, Thx..
Was hoping there was a way I could check it with out having to order the rings first first ..
QUOTE=wda-83wing;2101594]ok heres what the honda manule says ,
ring to-ring gland clearance
std.--- 0.02-0.05mm (0.001-0.002 in.)
servicelimit---- 0.12mm ( 0.005 in )
