Well I got my engine running from being frozen. My question is, What is a "Normal" engine noise ? I know a Rod Knock noise isnt good and I do not have that but on these Honda's (This is my first Honda) how "smooth" should it sound. Are there any YouTube clips of a "normal" 40k mile bike running. I do have slight ticking (Not knocking) and maybe a piston slap (Kinda like my Harley). I was just next to a new "2011" Goldwing and it was SMOOOOOOTH. Not sure how to compare mine to it.
Thanks.
Tony
Did you ballance/syncronize the carbs? I don't know of any clips to listen to.
If you just got it unstcuk and running, You need to use some mmo or seafoam in the crankcase for a 150 miles or so and try to clean that motor out. It could be a sticky lifter.
Hi Pryotex,
you have a PM,
Nick
PM returned, I will try the MMO and some Sea Foam in the Oil, It does have that Lifter tick to it.
PS I am still doing a Happy Dance that it is running. I even found a complete Radio on Ebay for $30 shipped (Kinda broken) but was able to replace the Pots on my with good ones and knobs !!
Rattleing sounds at idle is usually caused by unballanced carbs causing the primary chain to dance a bit. The transmission will be clunky, particularly in the lower gears. Otherwise, she should run quiet and smooth like you expect.
I've rebuilt my carbs and done several synchs, still rattles like a bag of bones, especially if I give it too much gas in a high gear.
Do a synch, go ride. These bikes don't like to sit.
